Door Latch Problems
Old Jul 20, 2018 | 10:27 PM
e21pilot's Avatar
Default Door Latch Problems
The left front door latch on our 01 VDP is starting to act up. It's mechanism is getting stuck internally and not allowing the door to latch properly when closed and sometime it doesn't open either.
I've tried cleaning and lubing it which seems to help for a few days but then it has problems again.
The part number for the latch is GNA1080BJ but it does not seem to be available anymore.
Does anyone know of a good source for a replacement part? Does anyone rebuild my existing latch?
Are these parts that commonly fail at this age? If not, maybe I could source a used one.
Old Jul 21, 2018 | 07:49 PM
Highhorse's Avatar
For used parts you can find the part or at minimum a yard close by using... Car-Part.com--Used Auto Parts Market
Here's one from Amazon...
Amazon Amazon
Have you checked the cable?...they are known to stretch and cause issues.
Almost forgot, check with David here... https://shop.everydayxj.com/Default.asp
Old Jul 21, 2018 | 09:39 PM
Lady Penelope's Avatar
There is one in Kansas City on a salvage car . Pretty sure only sold as whole unit . Chrome handle or not ? Try yours with the battery disconnected ..
Cost plus postage plus Trump tariff .
PM me
Old Jul 22, 2018 | 11:17 AM
JTsmks's Avatar
More then likely it’s the cable acting up, already replaced two on my XJR had to replace the similar setup on my old Lincoln LS, cables are readily available on Ebay for around $35.
rhriczko
Dec 26, 2019 05:45 AM
RSpi
Jan 21, 2014 10:21 PM
scchuck
Dec 3, 2006 07:26 PM
