Door panel clips where to get them?
Old Dec 24, 2024 | 04:16 AM
Silverjag0's Avatar
Default Door panel clips where to get them?
Hello i removed the door panel to replace the door lock actuator during the process the clips broke
If anyone have direct link to the door clips I would be thankful
Old Dec 24, 2024 | 08:27 AM
motorcarman's Avatar
The door casing clip is part number KTD300003.
No idea if they are still available from JLR.
Old Dec 24, 2024 | 09:03 AM
clubairth1's Avatar
Community Influencer
Your in luck I think?
Looks like jaguar KTD300003 has been superseded by jaguar KTD300002.
Door Panel Clips
BUT the superseded part number is very common and cheap. Many on Ebay. Terry's Jags carries them as well as Jagbits.
Ebay Door Clips
About $20 for 10-20 clips depending on where you source them.
You did not ask but those clips connect to another bit of plastic in the door and you may need them as well?
Part #KZV100010. About $6 each or so.
Door Panel Female Receptacle
Old Dec 24, 2024 | 03:21 PM
Jhartz's Avatar
Both male and female clips break: get a bag of each.
Old Dec 24, 2024 | 06:48 PM
bgilgall's Avatar
Default XJ8 door panel clips
I got 2 bags of.10 on ebay a few months ago. Did the job on my 2003 XJ just fine. Here's the link.
https://www.ebay.com/itm/20450962744...mis&media=COPY
Old Dec 24, 2024 | 09:53 PM
Silverjag0's Avatar
will get both clips male n female unfortunately the original clips very dry and breaks easily new one will solve it
Thank you
Old Dec 25, 2024 | 10:45 AM
stuizzy's Avatar
There are two different diameters of clips and two different types of female sockets. My 99 XJR needs the smaller clips which I got here. The larger ones work but are a little loose on the peg
https://www.ebay.com/itm/373334086895
The sockets need to have the groove so they clip into the hole. many for sale on ebay do not have this. The correct ones are available here
https://www.ebay.com/itm/363212091144
mghirsch
Nov 20, 2024 11:17 AM
David Dougherty
Nov 11, 2022 12:21 AM
stanislav
Nov 13, 2016 04:29 PM
bill586
Sep 2, 2013 11:10 PM
TopHatChef
Jan 2, 2012 09:17 PM
