drain oil and coolant for cam removal
Old Oct 16, 2011 | 10:22 AM
JagYi's Avatar
Default drain oil and coolant for cam removal
I want to remove the cam cover and check for upper timing tensioners.
Do you need to drain the engine oil and all coolant before doing this?
I wasn't sure if the DIY thread mentioned needing to do these steps...
Old Oct 16, 2011 | 11:33 AM
motorcarman's Avatar
Don't drain anything, just remove the cam covers to inspect the chains, tensioners and guides.
Replace the gaskets/seals unless they are fairly NEW.
bob gauff
Old Oct 16, 2011 | 04:43 PM
JagYi's Avatar
Thanks for the info. Will do as directed!
jagent
Sep 12, 2015 01:40 AM
OkieTim
Sep 8, 2015 04:48 PM
AL NZ
Sep 4, 2015 08:39 PM
Dicque
Sep 4, 2015 12:50 PM
OkieTim
Sep 2, 2015 12:48 PM
