Drivers mirror wont adjust
Old Feb 13, 2018 | 06:10 AM
Andmars's Avatar
Default Drivers mirror wont adjust
Riddle me this, the control does not adjust the drivers side mirror in any direction, but will adjust the passenger side.
If i manually adjust the drivers mirror into position, lock and unlock the car the darn thing moves back into a position it wants.
If i manually adjust the drivers mirror, and program the seat memory position, it still resets itself back into a position it wants.
Do i replace the whole mirror motor assembly? ....even though its able to move itself. Or is the problem somewhere else.
Old Feb 13, 2018 | 07:56 AM
yeldogt's Avatar
sounds like the control switch for left and right is bad -- if the mirror moves using the memory control all the wires to the mirror are good. flip the switch a few times and wiggle it while holding down the control and see if the mirror has any movement.
I have never taken that switch apart -- but often the contacts get fouled. Getting one from a wreck on e-bay may be in order
Old Feb 13, 2018 | 09:49 AM
motorcarman's Avatar
Why not adjust the mirror 'manually' and THEN reset the memory position????????
bob
Salieri
Jun 28, 2017 11:44 AM
mattjw1
Aug 6, 2016 06:46 PM
frombenz2jag
Dec 12, 2013 10:58 AM
jamesneely
Sep 3, 2012 05:07 PM
