Driver's Seat Won't Raise
Old Sep 9, 2014 | 06:39 PM
airtracker's Avatar
Question Driver's Seat Won't Raise
The drivers seat front up down has a problem , the motor turns but the mechanism does not raise or lower the front of the seat. Is there some kind of coupler or set screw that would cause this problem? The rest of the seat works just fine.
Don Little
1998 Jaguar XJR, 4.0 twin cam supercharged motor with Mercedes 5 speed transmission.
Old Sep 9, 2014 | 08:34 PM
Don B's Avatar
Welcome to the forum airtracker,
I've moved your question from the X350 to X308 forum, which is the forum for your model.
Please follow this link
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Cheers,
Don
Old Sep 12, 2014 | 07:27 PM
Lear45's Avatar
98 03 Jaguar XJ8 Front Left Driver Power Seat Motor 9410953C | eBay
The drive cable ends come off. Some just snap back in. 1/2 the time I have to replace a cable. There is a longer one and a shorter one. Not sure which one you need. If I remember correctly you need a Torx T45 to remove the seat. Only 4 bolts. Takes a couple of minutes. You can find an entire seat base for about $50 and have EVERYTHING if time is more important than saving $20.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
