ECM Rebuild
Old Jan 29, 2010 | 07:01 AM
Teddy's Avatar
Default ECM Rebuild
I have a 02 XJR100 that my mechanic has determined the ECM is causing the the O2 sensor to short. He has been unsuccessful in finding someone who has the ECM schematic to rebuild the ECM. Anyone have anyone who might be able to rebuild the ECM?
Old Jan 29, 2010 | 10:46 AM
Real_Tech's Avatar
Default Use caution please
I have personally installed several ECMs that were purchased by customers from various "rebuilders" and have yet to see one work properly. I have also sent 2 out to rebuilders at customers request to save money and neither worked when returned and I am still fighting with one of them for my money back. After sending the ECM back and forth to them at least 4 times it still did not work and they insisted it was fine and that something else was at fault. Wrong answer, the ECM from Jaguar worked fine. Most places that claim "rebuilding" of the ECM are just repairing common problems. If the fault you have is beyond a common problem they wont be able to fix it gauranteed. The same applies to the rebuilt ABS modules you see as well. If it is more than the common broken solder joint to the pump wires they can't fix the ABS module either. How else do you think they can offer module rebuilding for $75. The electronic parts alone to build either of these modules has got to be at least $250, have you ever looked inside? It's a scam, you pays your money and you takes your chances and good luck getting your money back when it doesn't work.
Old Jan 30, 2010 | 09:47 AM
Teddy's Avatar
Thanks for your personal experience on this.
Old Feb 3, 2010 | 06:27 AM
Teddy's Avatar
Update, I read my manual and determined the ECM and two other parts are covered under a longer warranty. In Canada it is 8 years and 130,000 km. Fortunately my car is still under warranty for the ECM. I had to point the extension out to the service writer. My ECM is on its way from across the pond.
Old Feb 4, 2010 | 04:50 AM
Real_Tech's Avatar
Excellent!
jospolice
Oct 2, 2015 07:16 PM
3lvis
Oct 1, 2015 01:56 PM
JTC3400
Sep 29, 2015 05:03 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
