Egine not firing
Old Sep 6, 2022 | 11:56 AM
paddeo's Avatar
Default Egine not firing
Earlier this summer I decided to remove and replace the original ignition coils on my 2000 xj8 with new ones due to constant misfiring problems I had been having. I had already replaced the plugs about two years ago and it ran great until earlier this past summer when it started acting up. When I was done replacing everuthong I tried to start it and It cranks but does not fire up. I used the car only a few days before and it ran OK, except for the misfiring problem. Now it just cranks but nothing else happens
Any help would be greatly appreciated. Thanks
Old Sep 6, 2022 | 12:36 PM
mayhem's Avatar
Have you checked for any DTCs? (Diagnostic Trouble Codes, aka check engine light codes)
Old Sep 6, 2022 | 01:26 PM
RandyS's Avatar
Pull a spark plug and see if you have fire during the crank first. If so, then you can
check the relief valve to see if you have pressure in the fuel rails, and if both of those
are good, then check for a compression issue.
Old Sep 6, 2022 | 05:47 PM
xalty's Avatar
foot to the floor put it in clear flood
Old Sep 7, 2022 | 11:58 AM
RandyS's Avatar
Yep, ...that goes without saying. A bore wash could be the whole problem.
Old Sep 7, 2022 | 07:43 PM
Parker 7's Avatar
You have a dedicated fuel injector and separate ignition coil relay
You can put your finger on them to feel them click closed so the injectors and coils are powered
Check for fuel pump relay clicking
On the other side of the fuel variable you may have put the engine in a bore wash condition , this would accrue easily if you lost your ignition
The 98 is the same as the 2000 in this aspect
fourkegdave
Jul 2, 2022 04:46 PM
Craighead
Dec 19, 2014 06:17 PM
ccbradley1
Jun 2, 2008 09:59 AM
Sep 25, 2006 10:33 PM
