EML light
Old Apr 24, 2015 | 08:22 AM
Heliwilly's Avatar
Default EML light
I have an issue with my EML light not working on my 2001 XJ8 Sovereign.
How long it has been like it I don't know.
I took the instrument pod out to replace the fuel gauge bulb. I thought I would do the EML light as well. The connector at the bottom of the pod was easy enough, but the 4 smaller white ones at the top have no obvious method of releasing them. Could someone tell me how it's done?
Bill W
Old Apr 24, 2015 | 09:09 AM
cybercg's Avatar
Default Me Too!
I would like to know the answer to your questions also. I couldn't figure the small top connectors out so instead of risking damage to the Instrument Pack, I abandoned trying to release them.
But, there has to be a way. Someone on the forum will know.
Old Apr 24, 2015 | 02:47 PM
Heliwilly's Avatar
Hi cybercg , I have just found out that you don't need to remove the 4 white small connectors to split the cluster.
If you remove the clear face to the instrument front.
At the bottom rear pull off the
Orange/Red Orange/Red
connector.
The socket it plugs into can, along with the 65mm by 35mm cct board it is mounted on, be carefully removed from the 2 white pegs it sits on.
The 4 ribbon connectors can then be carefully slid down the grooves they sit in and the 2 halves can be carefully opened like the page of a book.
I was investigating a non-operative EML light. It turns out that a previous "owner" had removed the LED to stop it coming on.
Me in my stupidity hadn't even realised that it hadn't been coming on even with the ignition!!!
I had been getting upstream O2 sensor faults 1646 and 1647, but no EML light. I was investigating how to split the instrument pod tonight and when I managed to get it open there it wasn't, LED 11 had been snipped out!!!!!!!!!!!
Does anyone know of the correct replacement LED?
Old Apr 25, 2015 | 11:58 AM
cybercg's Avatar
Heliwilly,
Thanks for the info about being able to open the PC board from the instrument pack body like a book. That is much safer than risking damage to the small connectors and ribbon cable.
Thanks for passing that on!
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
