Engine Falling On Its Face...
Old Feb 5, 2014 | 09:03 PM
JagginItUp's Avatar
I suspected the throttle body as well, dsnyder, but I was told that it would set a code because it crosschecks itself...and that its almost impossible to have a throttle body problem without a code set.
Old Feb 5, 2014 | 10:18 PM
dsnyder586's Avatar
Hmm.
Old Feb 6, 2014 | 07:27 PM
JagginItUp's Avatar
The more I hear you guys mentioning fuel pressure, the more that I think you may be right in guessing fuel pump... it could be losing efficiency under higher demand and causing all 8 cylinders to have a sudden lean miss..it would fall on its face as its doing, the computer would throw fuel at it by lengthening the injector pulse then on sudden full decel that positive trim causes a swing to way rich, so the computer goes "AH! Too much, take it back!"..
Then out of the blue it will take off like a bat out of hell...sometimes continuing to surge on acceleration, other times pulling hard to redline in Sport mode. I should also note that ABS and Trac Control are both offline.
Old Mar 4, 2014 | 09:36 PM
JagginItUp's Avatar
I think I finally found confirmation today while tossing scrap from the trunk with the car idling I heard the fuel pump drop in tone momentarily. Anther indicator, I think, is that while the SFT's are about zero but the LFT's are 15% positive
Old Apr 2, 2014 | 11:00 AM
First Jag XJR's Avatar
So I'm curious how this panned out for you JaggingItUp...did you put a new pump on? My 02xjr is acting identically to what you described. My Trac and ABS are down as well as you mentioned.
Old Apr 2, 2014 | 03:06 PM
danielsand's Avatar
After everything the OP did, my primary suspects at this point would be fuel delivery, and throtle body.
Old Apr 2, 2014 | 03:59 PM
tbird6's Avatar
Perhaps the fuel pressure regulator is misbehaving?
It should set a code and I am not sure the 4.0L engine has one.
Old Jul 12, 2015 | 12:05 PM
  #28
1951sms's Avatar
Was reading your text messages hear and you just stopped ?? what happened?
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
