Engine warning light / Electrical problems
Old Nov 6, 2008 | 10:29 AM
JimmyL's Avatar
Default RE: Engine warning light / Electrical problems
I assume you mean the yellow engine icon is lit. I have read my own codes, and it's not hard with any generic OBD2 scanner. The plug is under the dash near your right knee - if you have LH drive. If you get the codes, that will help a lot. My car sometimes doesn't do anything when I turn the key, but I try again and it will start right up, but nothing gets reset. That's a mystery.
Old Nov 11, 2008 | 11:09 AM
Peter.H's Avatar
Doesn't it sound like there's a loose connection somewhere? Have you checked the battery terminals, which can become slightly corroded and need a drop of terminal lubricant to make a sound connection. Also, check the wires from the starter switch (need to drop the lower cowl of the steering wheel to see). I recently had a glitch caused by a trapped (very fine) wire from the indicator stalk. I freed it and all was fine, although it then fell off but just needed soldering back on. Don't know, but it could be worth checking these things before you go spending a fortune on diagnostics.
Peter
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
tberry6686
Sep 20, 2015 03:22 PM
Oliver9218
Sep 3, 2015 05:33 PM
daro31
Aug 27, 2015 09:26 AM
