Error Code 1722
Old Nov 1, 2012 | 12:56 AM
Gippsland's Avatar
Default Error Code 1722
Would any one know what this error code relates to on a X308 ? Found while trying to find why the cruise control has stopped working...Neil
Old Nov 1, 2012 | 07:03 PM
coastaljag98's Avatar
that code fault description reads "P1722 Gear 2 Incorrect Ratio"
Old Nov 2, 2012 | 04:10 AM
Gippsland's Avatar
Thank You Coastal.jag98
We thought it was gearbox related..doesn't make much sense though..Appreciated.
Old Nov 2, 2012 | 05:10 AM
The full description from the Jaguar table for P1722 is:
Fault Description
Transmission stall speed failure
Default Action
When fault is detected:
1. transmission adopts limp home mode (5th gear)
2. ECM limits engine power
Possible Causes
1. transmission oil level low
2. selector cable adjustment / installation incorrect
3. output speed sensor problem
4. transmission failure
If there is no other issue that the code is present, there may have been a transient out-of-range signal from the output speed sensor to the TCM at some time.
Old Nov 3, 2012 | 04:51 AM
Gippsland's Avatar
Thank You Graham. You may have solved the mystery "transmission adopts limp home mode" AKA Engine Failsafe that keeps randomly appearing and has been driving me nuts.
Much Appreciated.
Old Nov 3, 2012 | 04:52 AM
Gippsland's Avatar
Much Appreciated.
Will P
Sep 19, 2018 08:36 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
Jpav27
Sep 26, 2015 03:33 PM
tonyforman
Sep 10, 2015 07:23 PM
