Error code: PO357 Coil "G"
Old Jul 5, 2014 | 03:26 PM
genec's Avatar
Default Error code: PO357 Coil "G"
Can someone please let me know which is Coil "G" and does the lettering system follow the cylinder number (A = 1, B = 2, etc) or the firing order? And also, are the cylinders numbered front to back like a small block Ford or left to right like a Chevy? Many thanks of course.
I replaced all ignition coils about 2 years (<10,000 miles) ago with new but cheap Chinese coils off ebay and a couple of weeks ago I started getting a PO357 Coil G Error Code, then a Random Misfire Error code. I decided to take it to a local mechanic, thinking it might be a wiring issue, and they replaced two coils themselves. Two days later I'm getting the same Coil G Error Code again. Any Thoughts? Again, thanks in advance. Gene
Old Jul 5, 2014 | 05:17 PM
Lear45's Avatar
Useful OBDII definitions list
http://www.actron.com/webfiles/OBDII...efinitions.pdf
Specific P0357 Coil G defined and possible solutions.
DTC P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
Based on my reading, it is #7.
Old Jul 5, 2014 | 07:25 PM
genec's Avatar
Thanks for the links. I'm going to swap F and g and see what happens.
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Bcrary3
Sep 27, 2015 12:21 PM
