Error Messages on 98 xjr
Old Dec 6, 2008 | 08:49 PM
brgxjr's Avatar
Default Error Messages on 98 xjr
Hey guys, got a question. I was driving on the freeway in traffic earlier today, and noticed that a orange light turned on in my dash, also my abs light came on, on top of that there were error messages concerning the traction control and the electronic stability or something like that. I got off the freeway, got to a red light and figured i would turn off the car and turn it back on to see if it would still read the same. I did that and the lights did not come back on. Im confussed on what it would be and why, i was not driving fast just stop and go? any help would be greatly appreciated on what i should do about it. Thnx.
Old Dec 6, 2008 | 09:46 PM
Brutal's Avatar
Default RE: Error Messages on 98 xjr
well let me reach over here....and grab...my argh.. crap I dropped mycrystal ball and broke it....damn, damn, damn now youre gonna have to go have the codes for the abs module pulled to see what it is...sorry, was gonna try to helpyou out
Old Dec 6, 2008 | 09:53 PM
JagtechOhio's Avatar
Something tells me that beaking your ***** would be a little more difficult then that.
Old Dec 6, 2008 | 10:50 PM
brgxjr's Avatar
lol, do you have another crystal ball? ok ok. i will try to go tomorrow and get the codes. but is it strange that they all appeared at the same time? or no. and why are they not showing now. Also if they don't come on again i won't be able to get the codes correct?
Old Dec 6, 2008 | 11:50 PM
Cerberus's Avatar
The module should store the codes, even if they're not active, so you should be able to retrieve them up until you intentionally clear the codes.
It's not rare for multiple systems to share errors when they share components. IE, the traction control and ABS both share wheel speed sensors and the same control module, so if there's a fault in either of those components, it will affect both systems. So, depending on what the error is, then it wouldn't be surprising at all.
Old Dec 7, 2008 | 08:39 AM
Brutal's Avatar
lol, glad you didnt take offense to my sometimes smart **** nature, but yes theyre all really one system ABS, and the only reason it went off after key cycle is its not a hard(constant) fault. And yes it should retain the code in the ABS module
Old Dec 8, 2008 | 01:54 AM
brgxjr's Avatar
well thank you both very much for the info. I would of turned a blind eye unless i would see the error codes appear again. No offense taken at all, I giggled and then felt kinda stupid. You hurt my pride a bit but.....sniff.....sniff....i think i ....sniff...will be ok........ lol thnx again ill try to go get the codes sometime this week. Untill then it will be parked in the garage.
peterg19
Feb 10, 2023 09:02 PM
scooternva
19
Oct 27, 2015 02:14 PM
Ipc838
Sep 13, 2015 03:27 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
XFR_Gold
Sep 2, 2015 12:24 PM
