Evaporator drain pipes question
Old Jul 14, 2013 | 03:40 AM
Maninahat98's Avatar
Default Evaporator drain pipes question
I have clean water pooling under the car which I believe is from the air con system....happens on most other cars I have had.
The workshop manual talks about 'Condensate (water)......forms on the evaporator........ drained out of the unit .........two drains, located either
side of the unit underneath...... liquid is routed to the vehicle exterior via flexible tubes which are located behind the firewall heat shield'
My question is ..is it normal for the water to drip off the bottom surface of the firewall heat sheild I mean the one around the top of the gear box? I can't see any drain pipes, just the water drips and pools on the floor. Don't mind, just doesn't sound/look right.....I was expecting the drain pipes to direct the water and dangle below the car slightly... Please let me know your thoughts on this. Thank you, Allan.
Old Jul 15, 2013 | 02:44 PM
Anyone know? Please? Allan
Old Jul 15, 2013 | 04:27 PM
Jhartz's Avatar
It is normal. JTIS shows the water will drain about where you are seeing puddling. Some condensate will blow back while you drive.
Old Jul 17, 2013 | 12:43 PM
Thank you Jim..... Allan
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
Russ Graber
Feb 23, 2019 11:59 AM
Scarecrow
Mar 28, 2016 03:17 AM
Saturbo
Sep 8, 2015 07:35 PM
