everything's fixed except driver window HELP!
Old Dec 25, 2012 | 12:15 AM
jimlombardi's Avatar
Hi
Look at this other thread. It maybe the same issue and remedy.
https://www.jaguarforums.com/forum/x...rs-door-63295/
The issue was the driver door switch pack (moisture getting into switch pack). Maybe of the forum member has a good used one for a reasonable price.
Part# is LNC6331BE - new part mspr price is $162.50, Gaudin discount price is $132.03. Used ones from recylers is about $100.
Try cleaning the switch pack to see if that fixes it.
Jim Lombardi
Old Dec 25, 2012 | 01:22 AM
jamies xj8l's Avatar
I dont believe its the switch pack because since I've been leaving the car unlocked its been fine. Only if i use my key to lock and unlock i am having problems so far. All windows work fi.e from the driver side switches, even memory seats an wheel.
Old Dec 25, 2012 | 08:03 AM
sparkenzap's Avatar
Given that, I suspect the SCLM. I bought one on ebay for about $100.
Old Dec 25, 2012 | 12:04 PM
Where is that box located? Maybe i can check the wiring and plugs?
Old Dec 26, 2012 | 12:54 PM
maggiedozie's Avatar
Have made copies of the control module & w. lifts. Will take them to my mechanic as he put in a new part for $289.00 and I've taken back twice and still doesn't work. I suggested it could be the part was inferior but he said they seldom were bad. I'm beginning to wonder if he really knows what he's doing.
Thanks for the info.
Old Dec 29, 2012 | 01:17 AM
sparkenzap's Avatar
jamie:
It is under the fuse panrl in the trunk.
Old Dec 29, 2012 | 03:06 PM
Hi
I created these 3 related files that show:
A photo of the fusebox inside of the trunk battery junction box:
https://www.dropbox.com/s/7bxeol7dls...ss%20Photo.JPG
Instructions & illustrations on how to unfasten the fusebox that is in the trunk battery junction box to access and remove the SLCM module
https://www.dropbox.com/s/pn18lur4rb...ox%20R%26I.pdf
SCLM module Pinout diagram with wiring information (increase your browser zoom to 125%, then click on image to get a clearer view of this info)
https://www.dropbox.com/s/jghlenn67w...out%20Info.jpg
Jim Lombardi
Old Dec 30, 2012 | 05:05 PM
  #28
Im very sad to know that the sclm im under the fuse box in the trunk. The previous owner had tried to replace the power antenna and did not put the vent hose back into the floor so the battery and fuse box area was under water when i got the car : ( i haven't had a chance to remove it yet and i gotta say im a little afraid too
Old Dec 30, 2012 | 05:28 PM
ozpacman's Avatar
I wouldn't be too sad about that - in fact I'd bet pounds to peanuts that your electrical gremlin might be living right there!
Russ
Old Dec 31, 2012 | 12:46 PM
  #30
Ok with 2 weeks of rain snow and not locking my doors the window has been fine! Im gonna start locking my doors today and see how long it last until reboot. If all works next will be opening my trunk. Im trying to narrow this down to what exactly is causing the slcm to act up. Wish me luck!!
Old Dec 31, 2012 | 02:15 PM
  #31
As expected.... Locked and unlocked the doors 4 times out shopping and the window is out and so is tbthe roof..what to try now? Unplug gas flap? It does not move ever and its plugged in?
Old Dec 31, 2012 | 03:29 PM
  #32
Well.... Went to reboot again and the positive terminal was leaking acid! Swapped out batteries for a new optima yellow top, while doing this i seen the gas tank strap bolts were finger tight! So i tightened those and am letting the computer learn now. We will see... Also unplugged the gas flipper motor..
Old Dec 31, 2012 | 04:22 PM
  #33
Shut off car... Locked doors waited 5 mins and unlocked and started..... No power window and Moonroof acting up. Gotta be something in one of the doors or the sclm.
Old Jan 1, 2013 | 08:27 PM
  #34
Tested micro switches in j gate today. Found both to be broken. Possible this is my security error? Gonna rebuild shifter tomorrow and see what happens.....
Old Jan 2, 2013 | 07:27 AM
  #35
Hi
Here is a thread on the J Gate repair - not much detail on repair, but does give info on the micro switches:
https://www.jaguarforums.com/forum/x...e-bulbs-74799/
Jim Lombardi
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Jpav27
Jul 31, 2022 06:43 AM
GordoCatCar
Jan 2, 2017 01:10 PM
avern1
Sep 8, 2015 06:25 PM
