Exhaust Manifold Torque Specs
Old Oct 24, 2018 | 08:01 PM
OUScooby's Avatar
Default Exhaust Manifold Torque Specs
What are the correct torque specs for the exhaust manifold? The factory service manual is oddly blank when it comes to listing torque specs on just about every thing and for the exhaust manifold it just says "tighten completely." Anyone know the correct torque, or should I just do them "German?"
Old Oct 24, 2018 | 11:16 PM
M. Stojanovic's Avatar
The service manual has some errors in the case of specified torques for the exhaust manifold. The torque table in the manual (attached) specifies 18 NM for both, the manifold to head and manifold to downpipe.
The bolts at manifold to head are M8 Grade 10.9 which is, according to the fastener torque charts, tightened to 34 NM. I decided to tighten my bolts to head at 24 NM (which is the torque for M8 Grade 8.8 bolts). When removing the exhaust manifolds, I found 3 bolts missing (loosened and fell out) so I used red high temperature threadlock on the bolts on re-installation because the new bolts from Jaguar parts suppliers come with pre-applied red threadlock (but sometimes come without it).
For the "manifold to downpipe" torque (the four M8 nuts), the manual shows 18 NM in the attached extracted table but it shows 60-80 NM for the "exhaust manifold to cat converter" in the section for exhaust manifold installation. Both appear to me incorrect, especially the 60-80 NM as, at this torque, the M8 studs would brake. I tightened the four nuts (which are Grade 8.8) at the flange manifold to cat converter to 30 NM (24 NM specified for M8 grade 8.8 plus 6 NM to compensate for the friction of the nuts as they are the locking type).
I also attach the general fastener torques chart.
File Type: pdf
File Type: pdf
Old Oct 24, 2018 | 11:55 PM
OUScooby's Avatar
Thanks, I guess I hadn't come across that page in the service manual yet. That explains why I didn't see it there, every other service manual I've used had listed the torque in installation instructions, or in a separate section just for that specific area of the car. 24NM - 34NM would be 18-25 ft lbs (sorry I'm used to working in ft lbs) which sounds about right to me, it about where I've seen most exhaust manifold bolts.
Old Feb 6, 2023 | 07:22 AM
Peter_of_Australia's Avatar
@ M. Stojanovic: Very good call on the 60-80Nm being way too high!
And thanks for the torque values by grade. According to this, 30Nm seems to me the right values as well.
jobagadonuts
Mar 19, 2018 04:17 AM
deelli
Aug 30, 2016 11:29 PM
Daim
Jul 13, 2016 12:55 PM
J_C_R
Apr 4, 2016 07:38 PM
djpxk8
Nov 10, 2014 06:18 AM
