Exhaust shield placement
Old Aug 11, 2012 | 03:05 PM
dsnyder586's Avatar
Default Exhaust shield placement
Does anyone have a blowup of where the heat shields go on an XJ8 at the manifold/cat junction? I didn't take note...
Old Aug 12, 2012 | 05:54 PM
xjrguy's Avatar
Well, this is sort of cryptic, but hopefully it will clear it up. Match the stud numbers with the hole numbers on the illustration. Install on the studs in the 1st, 2nd, 3rd order marked. All three studs will have a spacer on them, two are welded to the triangular bracket, the third may or may not be attached to the 1st shield. If it's not, just be sure it gets on stud three before you install the shield.
Good luck!
File Type: pdf
Old Aug 12, 2012 | 07:43 PM
jimlombardi's Avatar
Hi Steve
Nice response and informative diagram.
Jim Lombardi
Old Aug 13, 2012 | 12:36 AM
dsnyder586's Avatar
Definitely- Exactly what I was looking for!
Old Oct 6, 2012 | 03:50 AM
Guitarman944's Avatar
Similar problem here too do the alum shields go under the water filler side? And the fibre glass monstrosity on the other my XKr is right hand drive
Guitarman944
boiler
US Southwest
Dec 20, 2025 12:38 AM
Poet
Feb 7, 2025 02:18 PM
Joachim1167
Nov 7, 2020 09:18 PM
baskervillema
Oct 1, 2015 06:43 PM
