factory wheel alignment fixturing
Old Jan 17, 2014 | 05:51 AM
plums's Avatar
Post factory wheel alignment fixturing
Does anyone know how the factory checked the alignment on vehicles rolling off the assembly line? In particular, caster.
On some vehicles, for example the Pontiac Solstice and newest Corvette, there are two machined holes in the hubs to measure caster. The dealer tool for measuring rear suspension caster is a digital angle sensor with two pins that fit into the holes. The angle is read from a remote handheld controller.
Looking at the line drawings in JEPC, the only likely looking candidate is the ABS sensor mounting bore. The bore axis is in the same plane as the plane of interest so any rotation of the bore from the expected angle is equivalent to a change in caster. The face of the bore is also a machined surface perpendicular to the bore so it is also usable as a reference surface.
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
1964Daimler
Sep 9, 2015 11:28 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
