Fan staying on full blast once the car starts
Old Jan 21, 2017 | 07:03 PM
Dannyaspect34's Avatar
Default Fan staying on full blast once the car starts
Brought the car test drove it went lovely came back opened the bonnet noticed the fan was running thought nothing of it
Just wondering after reading a few links is one of the main reasons because the thermostat needs changing ? It's a XJ executive 2002
Never went above half temp
And is it worth doing the water pump at the same time
Dan
Old Jan 21, 2017 | 07:04 PM
Meant to say staying bloody spell check
Old Jan 21, 2017 | 08:52 PM
Highhorse's Avatar
Meter your temperature switch with the vehicle off and cold. You shouldn't have a continuity, and if you do, there's your culprit.
Old Jan 22, 2017 | 01:55 AM
Ok thanks will have a look at that
Old Jan 22, 2017 | 01:15 PM
Reading other bits on the website it wouldn't be because the water pump or thermostat is faulty
Dan
Old Jan 22, 2017 | 05:04 PM
Highhorse's Avatar
Definitely not saying it is, but it doesn't hurt to meter it to eliminate it as a possibility.
Old Jan 23, 2017 | 01:51 AM
highhorse I totally agree it's just nerve racking when u pick a car up find the fans running and see all the horror stories
will start with the cheapest item first like u said and go from there
Old Jan 23, 2017 | 06:55 PM
Ron Brooks's Avatar
Mine was doing that until I put in a new thermostat !
Old Jan 24, 2017 | 08:53 AM
RJ237's Avatar
The title of the thread suggests the fan runs as soon as you start the engine. If that is true, is the AC on?
Or do you mean the fan runs for a short time after the engine is shut off? My XK8 does that, but it's part of the ECU programming if the engine is up to operating temp.
Old Jan 24, 2017 | 05:01 PM
Thanks Ron Brooke's got it booked in for a new thermostat and have a new water pump as well just in case
Old Jan 24, 2017 | 05:04 PM
thanks rj237
the fans come on as soon as you start the car slow and as soon as the temperature come off of cole there on full power they turn off as soon as u turn the car off
i think the thermostat has had it so having one fitted Thursday as well as a new water pump if needed and thermostat sensor as well so I know it's all ok
will let u know how it all gos
Old Jan 25, 2017 | 06:11 AM
Daim's Avatar
Can also be a faulty sensor. Mine was thought to be dieing but it wasn't. Fitted a new one and the fan was on on a cold engine... Cold engine doesn't need cooling...
Old Jan 25, 2017 | 06:18 AM
Mia that the thermostat sensor ??
ifso have another one of those to go in as well so fingers crossed I should have a lovely running engine with no fans running Friday
Old Jan 25, 2017 | 12:34 PM
Daim's Avatar
Near the thermpstat cover... On the crossover pipe infront... Should habe a grey plug...
Old Jan 27, 2017 | 09:53 AM
Well good news on the fans staying on turns out to be faulty air con switch it's been unplugged and fans are all sorted so now to buy a new switch
Poet
Apr 11, 2022 06:51 PM
aholbro1
Feb 5, 2017 10:15 AM
santi
Jan 16, 2017 05:52 PM
Bigredjaguar
Nov 21, 2016 07:33 PM
