Fans staying on too low? Still on at 165 degrees?
Old Aug 19, 2013 | 11:12 PM
WaterDragon's Avatar
Default Fans staying on too low? Still on at 165 degrees?
It was working the other day, on at 203ish and off at 193ish.
Now it seems to stay on far too long, even when I restart the car and the water temp was only 165 the fans came on.
Is there some control thingy do dad I need to replace?
Old Aug 20, 2013 | 03:52 AM
sparkenzap's Avatar
Is your AC on?
Old Aug 20, 2013 | 05:56 AM
Nope.
Update...they are acting fine today. Wierd.
Old Sep 2, 2015 | 06:57 PM
dsnyder586's Avatar
I am reviving this thread, as I have a 2000 XJ8 that is running cool (fans on all the time low speed) runs about 160-180 unless I unplug a fan then it goes 200+. What gives??
I am currently working through a fuel pump swap, so it is not urgent, but I was hopng to get that done at the same time so....
Old Sep 3, 2015 | 04:04 AM
test point's Avatar
How are you measuring the temperature? If with an IR gauge then the temp sensor is suspect. If with a TORQUE app or Real Gauge then the fan module (relays).
Old Sep 3, 2015 | 10:45 AM
dsnyder586's Avatar
Hmm. might be the fan module- where would that be located?
I am using an OBD2 reader for temp.
Old Sep 3, 2015 | 05:02 PM
Jhartz's Avatar
Might also be a sticking AC pressure switch. When the AC is on, the fans start; when the compressor runs, fans go to high speed. If the pressure switch is sticking, it might not be getting the signal to shut down.
Pull the switch when the fans are running: if they stop . . .
Old Sep 3, 2015 | 05:30 PM
test point's Avatar
Fan module is located sorta under the radiator on the left side. Accessed from under the car.
Old Sep 4, 2015 | 06:24 AM
dsnyder586's Avatar
Ok- random result- I had a fuel pump faliure, replaced it and the fan/running cool problem vanished.
Old Sep 4, 2015 | 09:27 AM
RJ237's Avatar
Only on a Jaguar. Good luck.
afterburner1
Dec 16, 2015 12:12 AM
abonano
25
Sep 25, 2015 10:43 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
