Fault lights in HOT weather
Old Feb 22, 2026 | 05:33 AM
HeyCharger's Avatar
Default Fault lights in HOT weather
My X308 4.0l gets the normal fault lights, gearbox fault, Trac not available, ASC not available, fail safe engine mode, ONLY when driving in the city on a hot day (30 deg C plus).
I normally turn into a side street, turn the engine off and raise the bonnet.
30 min later, it's all cooled down and off I drive.
Thoughts???
Old Feb 22, 2026 | 07:28 AM
Vauxi's Avatar
Abs unit is getting hot and bad solder joints do not make any connection anymore. I'll bet you'll have faultcode about pump motor in abs module.
Old Feb 22, 2026 | 11:12 AM
RandyS's Avatar
There are many postings that indicate how this can be repaired. it may be wise to do
a search, and check what is involved.
Ant Buck
Feb 2, 2025 11:05 AM
HeyCharger
Oct 9, 2024 09:37 PM
trainfan
Jul 2, 2022 06:29 PM
rht54
Mar 1, 2016 07:03 AM
okistag
Aug 9, 2010 04:02 AM
