a few error codes...
Old Jan 12, 2008 | 12:47 AM
drog321's Avatar
Default a few error codes...
My car threw these two errors:
P0308 - cylinder 8 misfire
P1316 - injector driver misfire
When i accelerated to leave a parking lot, the car kind of sputtered, which I assume was a misfire.
Any ideas for a possible fix? Can a simple fuel injector cleaning relieve the issue.
I had a tune-up 200 miles ago and had all spark plugs replaced, and a seal inside the engine because it was leaking oil. Thanks-DR
Old Jan 12, 2008 | 05:35 AM
FactoryJaguarTech's Avatar
Default RE: a few error codes...
hard to answer. If you just had plugs replaced, maybe gap not correct on cyl 8.
Normally if vehicle needs injector cleaning, will list codes p0301 - p0308
Also, if cam cover gaskets are leaking could have fouled plug. Pull it out and see.
Old Jan 12, 2008 | 10:05 AM
drog321's Avatar
thanks for the response
the cargave the cylinder 8 misfire prior to the tune-up as well.
what is the "P1316 - injector driver misfire"
thanks!!!
Old Jan 12, 2008 | 06:11 PM
P1316 flags after a misfire code flags. It is for Excess emissions only. Just lets you know it misfired.
ricwel
Jun 23, 2023 05:14 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Msteiner
May 16, 2016 12:19 AM
Poet
Oct 2, 2015 09:00 AM
Collector1
Sep 28, 2015 03:52 AM
