Few problems want some advice
Old Nov 22, 2010 | 07:51 PM
XJR-0220's Avatar
ud
Default Few problems want some advice
Ok well still working on getting this car going properly so the first step was a tune up but after changing the plugs to some brand new NGKs the car wouldnt start. I went with NGKs cus I am a HUGE fan anyway tried 2 sets but car would not start. They would just get fuel soaked. Then decided to put the original plugs back in and boom started right up, weird................. went and bought some brand new factory champion plugs (an I hate champions) and like magic started right up. Called the jag parts depot and they confirmed that the engines run best with the factory plugs.
Ok now onto the little things that are annoying me. Car runs smooth but seems to have a small stubble when I first push the gas, dont know why but kinda stubbles before it gets going. It doesnt seem to go into first well kinda seems like it starts in 2nd, but found out the downshift switch wasnt working great took alot of effort for it to kick into the downshift any way to adjust this??.
Check engine light came on dont know what it is yet dont know how to check codes on it. Also for having 322hp and 378 torque shouldnt it get up and go pretty good??? Mine seems to only get going moderately decent I just installed a new blower belt and tightened it perfect the factory original was on it and man was it beat to hell cracked, frayed and loose. Well let me restate that I had to order the factory 7 groove belt it will be here tomorrow and in the mean time I put on a 6 groove, do you think it may be slippin having 1 less rib?? Also anything I should look into replacing while I am getting it ready for daily driver duty?? Love the car so far havent gotten to take it out much cus Im wanting to make sure it runs properly. I changed plugs, fuel filter, all belts, air filter, oil change, new tires, cleaned the maf, tighten up hoses and checked connections, gunna service the trans (what fluid should I use) Thanks for any help guys
Old Nov 23, 2010 | 08:55 AM
XJR-0220's Avatar
ud
noone has any thoughts??
Old Nov 23, 2010 | 09:16 AM
lightninfil's Avatar
im guessing your car is an 02 because of your name?
Old Nov 23, 2010 | 09:26 AM
sorry i messed up my reply. if your car is an 02 the factory plug is a ngk ir ifr5n 10. that is the number off of the plug itself. the factory part number is c2a1535. hope this helped.
Old Nov 23, 2010 | 06:23 PM
XJR-0220's Avatar
ud
No mine is a 95 and I got it figured out I was told it needs to use a champion plug and sure as **** the min I put in a new set of champions it fired right up
Old Nov 24, 2010 | 06:05 AM
steve11's Avatar
ud
Champion RC12YC or RC12YCC work best in your engine. They're the right temperature range and are traditional copper (or copper/copper in the CC) and should be changed about every 25 to 30K miles. Nothing else is going to run well in this engine.
Old Nov 24, 2010 | 06:22 AM
steve11's Avatar
ud
Sorry, I got my Ys mixed up, did this from memory. The plug is RC12YC or RC12YCC
PMKimpton
Aug 3, 2019 08:22 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
