Fixed P1647, now got P0174
Old Sep 30, 2014 | 07:57 AM
talulah's Avatar
Default Fixed P1647, now got P0174
I recently fixed my upstream lambda sensor which was reporting a P1647 fault (described in a separate thread), cleared the fault code, and was happily diriving for the first time without an engine warning light, when a few miles later up popped the message "Performance restricted", and another engine warning light, with a DTC of P0174 (System too lean, bank 2)
Researching this I know there are many possible causes, but the most obvious to me is that the lambda sensor that I replaced the Denso one with is not giving the right signal. The one I bought was from ebay here. When it turned up it looked exactly like the Denso one I had taken off, and had a heater resistance of 2.5 Ohms which seemed about right. but did not have Denso written on it like the old broken one.
I was thinking of buying another sensor from Eurocarparts, this time a Denso one, but I don't want to spend another £70 for no reason. What do you all think?
Old Oct 1, 2014 | 06:04 PM
fredd60's Avatar
Default p0174
After replacing sensor, did you do a hard reset?
Attach an OBD reader and set it to log LTFT and STFT on both sides while you drive; might give a clue to what is happening.
Old Oct 1, 2014 | 10:06 PM
yeldogt's Avatar
If you are getting an additional code you either have another problem or the wrong sensor
Old Oct 2, 2014 | 04:44 AM
talulah's Avatar
Thanks for that. How do you do a hard reset?
....it's alright - I looked it up!
Old Oct 2, 2014 | 04:57 AM
talulah's Avatar
Thanks for that. I'm suspicious of the sensor so I think I might buy a new one - a genuine Denso one this time - and if that fixes the problem try to get my money back on the other one.
Old Oct 2, 2014 | 09:06 AM
Jhartz's Avatar
Used to get the 174 on my RR SC. A bottle of Lucas, or Gumout's Best always seemed to clear it within a day or two (need to reset of course). Lately, found SeaFoam also cleans the injectors better than the other two. Might try that first. Dirty injectors cause a lean read . . .
clubairth1
30
Sep 3, 2025 04:38 PM
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
