Foam Pad Under the Supercharger
Old Mar 17, 2010 | 03:15 PM
sparkenzap's Avatar
Default Foam Pad Under the Supercharger
Does anyone know what the purpose of the molded foam rubber pad between the block and the supercharger is?
Old Mar 17, 2010 | 03:19 PM
Brutal's Avatar
to increase hp by reducing heat transfere into case from engine, also helps to absorb SC noise
Old Mar 17, 2010 | 06:29 PM
sparkenzap's Avatar
Thanks!
Old Aug 12, 2012 | 08:56 PM
pyccku's Avatar
where can i buy a new foam thing. i searched and dont even know what the proper term for the foam is called
Old Aug 13, 2012 | 01:29 AM
thinkpad_master's Avatar
It's called "Sound insulator". I checked on the Jaguar EPC and the part # is AJ82383. I just tossed mine out when I put the new coupler in my supercharger, it was getting in the way during install. I don't know if I actually lose HP from extra heat, but I haven't noticed an actual noise increase.
Old Aug 13, 2012 | 10:47 AM
XJR-0220's Avatar
Also there to keep the heat from the charger from transferring into the hose or vice a versa haha
kthrash
Feb 25, 2019 10:20 AM
vwbusbits
Oct 13, 2015 03:43 AM
dmatthewman
Sep 30, 2015 10:10 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
