Front End Nuisance
Old Mar 26, 2011 | 07:54 PM
pezzonovante88's Avatar
Default Front End Nuisance
Going over small bumps or slightly rough roads (not big bumps) there is a very annoying bird chirp-like squeak. It is really only audible with the windows down. My indy mechanic couldn't diagnose it. He shifted the exhaust system around, checked bushings, etc. Any thoughts on what it could be?
Old Mar 26, 2011 | 09:06 PM
H20boy's Avatar
sounds are very hard to diagnose...at what speed? Can you take a video with sound and post it up?
Old Mar 26, 2011 | 09:19 PM
Can't record the sound now, as the car is in storage. But, it seems to occur in residential areas and anywhere with speed limits around 20-70 kph (12-45mph). I cannot notice it on the freeway, perhaps because there's too much wind noise.
Old Mar 27, 2011 | 05:13 AM
Sean B's Avatar
probably a dry bush. It's a case of having a look underneath the vehicle. A can of lithuim spray grease or similar, and light squirts on suspension bushes on all four corners.
Old Mar 27, 2011 | 02:02 PM
Sinister 1's Avatar
Sounds like your mechanic was on the right track. I found the heat shield on my driver side first catalytic convertor was chirping.
Old Mar 27, 2011 | 06:23 PM
ka1thm's Avatar
Default Same Problem-Found bushing on lower arm bad
The mechanic cannot diagnosis the bushings properly if he has the bushing loaded with weight from the front end. I had new bushing pressed in and away went the squeak in the right front end.
<<<Mathew>>>
Old Mar 27, 2011 | 07:02 PM
Interesting. Well, I can hardly wait to get the car out in two weeks and have this sorted. Thanks.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
johndahlheimer
Sep 16, 2015 05:44 PM
XKR-NC
Sep 4, 2015 08:23 AM
