Front right shock stuck?? Pls help
Old Sep 29, 2013 | 05:07 PM
pdog2000's Avatar
Default Front right shock stuck?? Pls help
It appears that my front right shock is stuck or something like that...when I push down on the front right of the car it doesn't move hardly at all...and the only thing that appears to give a little and compress is the top rubber bushing that I can see under the hood ...any idea what it is and if I can still drive the car...I just had a new engine put in so could that have anything to do with it? A own shock or bad spring? Pls help
Old Oct 2, 2013 | 06:49 AM
bearh3526's Avatar
Default Shock Issue
Sound like the shock has lost all its fluid. If so then the shock is bottoming out. If it were the spring you would be able to see a crack in the spring. The shocks are not that expenses, however check the top rubber bushing they are NOT part of the shock and if they are worn, and you will not be able to tell, tell you remove the top nut of the shock they are expenses like $ 200.00 just for those bushing. make sure you check the spring too. This would not have anything to do with your new engine since you do not have to take the front in down to install an engine. Hope this helps
Old Oct 2, 2013 | 07:50 AM
pdog2000's Avatar
I just ordered the shocks and all the spring rubbers from britishparts.co.uk...I didn't order the springs but maybe I should
Old Oct 5, 2013 | 02:19 PM
pdog2000's Avatar
And funny enough the right front shock is now unstuck and works fine... What is that all about... Was it stuck in place and then just popped free when I hit a bump...I am still having it replaced...
Old Oct 18, 2013 | 11:47 PM
pdog2000's Avatar
New shocks are a-ok...and all back to normal
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
KarimPA
Sep 12, 2015 08:15 AM
Tar
Sep 6, 2015 11:24 AM
