Fuel Pressure Spec for 99 XJ8?
Old Mar 19, 2011 | 08:33 PM
Sinister 1's Avatar
Default Fuel Pressure Spec for 99 XJ8?
Anybody have the spec at Idle and WOT handy?
Old Mar 19, 2011 | 08:47 PM
sparkenzap's Avatar
40-41 psi above manifold pressure.
Old Mar 20, 2011 | 10:50 AM
Sinister 1's Avatar
Thanks Sparky!
At WOT I've got 41 psi solid as a rock. I know vacuum will be next to nothing at WOT so that one looks good to me.
At Idle and part throttle I've got 34 psi.
I'm without a vacuum gauge so does the idle reading sound about right?
Old Mar 20, 2011 | 12:21 PM
sparkenzap's Avatar
Well, a 7 psi drop would match 14" of mercury which seems like a reasonable vacuum reading at idle.
You did not ask, but the fuel pressure at WOT UNDER LOAD can drop off due to the pump's inability to supply volume. What you have proved so far is that your regulator is working fine, and the pump can supply pressure at low volume. To test under load, I use a long hose on my fuel pressure guage, with the guage taped to the OUTSIDE of the windshield, then go for a drive.
Old Mar 20, 2011 | 07:42 PM
Sinister 1's Avatar
Yep. My 41 PSI figure was with the accelerator mashed to the floor going up a nice steep hill. I had the gauge zip tied to the windshield wiper arm.
Thanks for the conversion on the Idle pressure.
Ken
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Bcrary3
Feb 21, 2023 04:29 AM
ccfulton
Sep 20, 2015 05:15 PM
