Fuel Pump Question
Old Feb 24, 2013 | 05:26 PM
kenncl's Avatar
Default Fuel Pump Question
Have a dead fuel pump and have been trying for hours to find the two lines at the bottom of the tank. I have read all the posts here but for the life of me I can not locate the connections hidden up over the differential. The car is jacked up high and I have the quick release tools but I can not find a way to get to the connectors. Any tricks I should know???
Just a side note. Finally replaced the throttle body due to intermittent failsafes. Went pretty well and when I started the car it went into restricted performance and a code P0332. I had already replaced the other knock sensor and went ahead and replaced the this one. Started up and no failsafe but now trac and stability failures so was going to let car run to charge up battery and take to have abs codes run but upper coolant hose blew. Replaced hose and again let run and it died and was unable to restart with no codes. Bad fuel pump. In the six years we have owned this car starting at 67K we have replaced all O2 sensors, both knock sensors, thermostat housing, water line under the railing, throttle body assembly, all disc pads, door lock cylinder, plastic part in the rear trunk assembly. In six years we have only been able to put on 23K miles due to continued problems. AAGHHH!
Thanks Guys
Old Feb 24, 2013 | 06:35 PM
coastaljag98's Avatar
U have to have small hands and alot of paitence. U won't see the connections but feel them when u reach up over the driver side of the differential. U can do it but don't take that tank out before u are sure it's disconnected.
Old Feb 24, 2013 | 07:24 PM
kenncl's Avatar
Default Thanks Coastal
Will give another try. I did notice the quick release tools were color coded by size. Do you remember the color/size that was needed.
Old Feb 25, 2013 | 01:19 AM
Bug Splat's Avatar
I Just replaced mine in about 2 hours. I know this is not the proper way to do it but it worked for me. I removed the tank straps, the rubber boot where the fill cap is, and the drain pipe. I also disconnected all the tubes I could. Then I slowly and gently began to wiggle the tank out with the bottom lines in the tank still connected. It took a lot of pulling but I was able to pull the tank out far enough to remove the top and reach in and replace the pump. It was not easy but I got it done. Again this IS NOT the right way to do this. Try at your own risk.
Old Feb 25, 2013 | 01:49 AM
plums's Avatar
It's been done that way before.
The people doing it have noted that there is more wiggle room if the plastic clamps holding down the fuel lines to the chassis are released and the fuel filter removed.
Old Feb 26, 2013 | 02:04 PM
kenncl's Avatar
Bug Spat, been trying to get the lines disconnected and just can not reach the lines. When you wiggled the tank out did you lean it certain ways or one end first. Having a young man in last semester learning to be a diesel mechanic come by and take a look this weekend but his hands are larger than mine(lol).
Old Feb 27, 2013 | 01:01 AM
Bug Splat's Avatar
I used a large box wrench as lever against the bottom rim of the tank and the trunk floor. One side at a time I would pull the tank out maybe 1/4 inch each time. I found what worked best was to grab the fill pipe with the left hand pulling it and use the wrench on the bottom right side and just go back and forth wiggling it out. It took a long time but I was able to pull it out enough to angle the top toward me to reach in. I hope this help. Good luck.
Old Feb 27, 2013 | 04:04 PM
kenncl's Avatar
Default It Worked
Thanks Bug Spat, Did just as you said and had it out in about 15 minutes. I had to cut one of the rubber fuel lines on top as it would not budge. I did find an answer to the color of the quick release tool to use which is light blue for those wishing to go that route.
Again, thanks everyone for your help.
We do need to start a betting pool on which other part(s) will need replacing as soon as I start up the car with the new fuel pump.(lol)
Old Feb 28, 2013 | 01:33 AM
Bug Splat's Avatar
So glad to hear you got it out.
No way am I putting money in a pool for Jag repairs. I was only expecting to replace the pump and battery and walked into 120 hours worth of work and about $3,000 in parts, paint, and leather repair. Not a bad deal considering I got the car for free but I sure walked right into the bears den. I do all my own work and I like working on cars but I can't even begin to imagine how much a Certified Jag repair shop would charge to do all the work. I have everything fixed now and it runs like a dream. I love my XJ8.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
deanh
Sep 6, 2015 08:20 PM
Sprayall
Sep 3, 2015 07:49 PM
