Fuel and temp gauge stuck
Try a hard reset (disconnect the battery minus wire from the battery and touch it to the positive post for a few seconds, then reconnect it).
If that does not work, your instrument cluster has likely seen its last day.
If your other gauges are working, chances are the sender in the fuel tank needs to be replaced.
