Fuse for accessories?
Old Mar 2, 2022 | 03:29 AM
Svalbard's Avatar
Default Fuse for accessories?
Many years ago, I had a card reader for automatic toll booths installed.
It's worked good until lately. I suspect it might be a fuse.
Does anyone know which is the fuse for accessories?
Old Oct 11, 2025 | 03:22 AM
Floughy's Avatar
Default Fuse 1 fuel 14
Bonjour
J'ai eu également le voyant fuse 1 avec en détail fioul 14 qui sont apparus.
J'ai vu que c'était certainement le capteur de température d'air qui était en cause , je l'ai donc changé car en effet il était vraiment pourri.
Depuis je n'ai plus le voyant fuel 14, mais le voyant fuse 1 apparaît toujours.
Malheureusement, j'ai beau lire tout ce que je trouve sur le sujet, je n'ai aucune idée du fusible que je dois changer.
J'ai bien repéré les fusibles de droite et de gauche, quand je les sors ils m'ont l'air tous en bon état mais je n'ai aucune idée duquel je dois changer
Pouvez-vous m'aider ?
Old Oct 11, 2025 | 11:08 AM
Jhartz's Avatar
Translated, he asks:
"Hello
I also had the fuse 1 light with fuel oil 14 in detail that appeared.
I saw that it was certainly the air temperature sensor that was involved, so I changed it because indeed it was really rotten.
Since then I no longer have the fuel 14 light, but the fuse 1 light still appears.
Unfortunately, no matter how much I read everything I find on the subject, I have no idea of the fuse I have to change.
I spotted the right and left fuses, when I take them out they all look like they are in good condition but I have no idea which one I have to change
Can you help me?"
Really tough to answer or help: what car, year, model: although it translates (literally to "fuel 14 light, but fuse 1 light" have no clue what he is asking
Old Oct 11, 2025 | 11:12 AM
Floughy's Avatar
I'm sorry, it's a xj40 sovereign 3.2L de 1992
Old Oct 12, 2025 | 06:12 AM
Hooli's Avatar
You're in the wrong section then, you need to be posting here
https://www.jaguarforums.com/forum/xj40-xj81-25/
I expect one of the mods can move this thread for you.
Chris Brindle
Jul 6, 2021 01:07 PM
OUScooby
Dec 31, 2019 09:48 PM
obwoodie
Dec 12, 2015 10:01 PM
Jagmag
May 1, 2012 06:55 AM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
