Fuse blows when trunk opens - xjr
Old Jun 24, 2009 | 11:33 AM
johnleavitt's Avatar
Default Fuse blows when trunk opens - xjr
Whenever the trunk lid is opened more than a couple of inches on my 2003 xjr, the number 7 15 amp fuse in the drivers side rear seat fuse block blows. It does not blow when the trunk mechanism is activated, but only when the trunk gets past a few inches open. It seems like maybe a mercury switch or something in the lid that turns on the lights, but I cant seem to find one.
This is a real pain because when this fuse blows, it locks up the shifter and it won't come out of park without the manual overide. Any ideas?
Old Jun 24, 2009 | 03:57 PM
Sarc's Avatar
Default Maybe ?
Not had this myself but could it be a problem with the wiring that runs into the trunk lid for at least the license plate lights and also the locking mechanism ?
I think the wires are hidden under plastic covers that run down the trunk hinge arms..... you may want to take these plastic covers off and have a look and see if the wiring loom has somehow gotten damaged and you are getting bare wires shorting out when you move the trunk lid ?
Old Jun 24, 2009 | 05:10 PM
sparkenzap's Avatar
SARC is right! The wiring harness at the hinge is known to rub the insulation and cause various short circuit problems.
Old Jun 27, 2009 | 02:26 PM
So I took off the plastic cover and found the wire bundle to be in new condition. I pulled it off the hinge to look at it...put it back. Could not find a problem.
The good news is that now its fixed. It probably healed on its own, like all electrical problems can, or when I manipulated the bundle, it unshorted. I hope it stays that way.
Old Jun 28, 2009 | 10:55 AM
JackJohn's Avatar
John, most things that fix themselves have a nasty habit of coming back to haunt you at the most inopportune times. There's a wire in that bundle with a bare spot in it and it will find it's way to ground again.
Old Jun 28, 2009 | 04:26 PM
Yes, I am sure it will, and I will order some of the disposable fasteners that hold the carpet to the trunk lid so I can remove the carpet and investigate further. When I manipulated the wire bundle, I could hear the harness under the carpet moving. I would bet that the problem lies there. I want the fasteners in hand so I don't end up storing the carpet in my garage for the next three years while I get to putting it back, if you know what I mean.
dsnyder586
Dec 29, 2024 07:39 PM
martybmw
Apr 2, 2016 04:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
jehart49
Sep 12, 2015 05:36 PM
Corycarlo
Sep 5, 2015 11:41 AM
