Gas mileage for XJR 99?
Old Jan 7, 2010 | 11:39 AM
DjiXas's Avatar
Default Gas mileage for XJR 99?
Hi,
So I've been reading some of the topics and noticed, that you guys, are having mileages like: 20 mpg, etc.
I have Daimler V8 Super 1999 and computer states that it is using ~20 liters/100km (~11.8 mpg) with sport button off.
Is this normal? If no, what do you suggest?
Old Jan 7, 2010 | 12:34 PM
DavidB's Avatar
I have a 2000 Vanden Plas Supercharged, basically the same model as your car.
11.8 MPG sounds a little low, but is believable with cold temperatures, short trips, and no highway driving.
First, I'd check your computer's calculation with your own math at a fill-up. My trip computer consistently shows that I've used one more gallon than I really have, which shows up as a lower displayed MPG than what I'm actually getting.
I only use sport mode and in mostly urban driving, I'll average around 15 MPG (US gallon). A long trip at highway speeds (70-80mph) will barely squeak over 20 MPG (US gallon).
TTYL
David
Old Jan 7, 2010 | 12:41 PM
DjiXas's Avatar
Thanks for your reply. I'm driving on a highway/city 50/50. Will try to fill up the tank and do some calculations then.
Old Jan 7, 2010 | 01:07 PM
Markus's Avatar
My 1999 XJR also gets 10% better actual mileage than the trip computer shows, I average 17mpg around town, 22 on road trips (steady 80mph), and 6-7 mpg at a steady 130+...
Sounds as though you might need to replace your air filter element and possibly spark plugs as a first effort at better fuel economy.
________
IOLITE VAPORIZER REVIEWS
Old Jan 7, 2010 | 02:16 PM
DjiXas's Avatar
Spark plugs were replaced ~1 month ago, not sure about air filter, will check.
P.S. How many gallons/liters does fuel tank hold?
Old Jan 7, 2010 | 02:31 PM
DavidB's Avatar
Capacity 23.1 US Gallons / 87.4 Liters
Gauge should indicate empty at 19.8 US Gallons / 75 Liters
Another thing to consider is the ethanol content in your fuel. My area requires all gas to be sold with a minimum of 10% ethanol, which negatively affects mileage. My economy numbers might look more like Markus's in an area with no ethanol.
TTYL
David
Old Jan 8, 2010 | 05:55 AM
cafepombo's Avatar
98 XJR around town is getting something like 11mpg. That supercharger makes a lovely whine as it winds up though...
Probably worth checking my air filter I guess. I have a little scooter for around town and with the same amount of petrol, I can travel over ten times the distance!
Old Jan 8, 2010 | 06:30 AM
Markus's Avatar
Default Good point, David!
"Another thing to consider is the ethanol content in your fuel. My area requires all gas to be sold with a minimum of 10% ethanol, which negatively affects mileage."
I have noticed increased fuel consumption and decreased power when forced to use gasahol. The old saying "alcohol and cars don't mix" has great merit, IMHO - on many levels!
________
VAPIR NO2 PRICE
Old Jan 8, 2010 | 07:53 AM
DjiXas's Avatar
Air filter was changed in autumn, so guess it's as good as it can get.
Forcedair1
Feb 19, 2020 01:51 PM
Broken_Spanners
Dec 11, 2015 04:14 AM
Ipc838
Sep 13, 2015 03:27 PM
Busa R
Sep 10, 2015 07:28 PM
