climate control sensor?
Old Jan 7, 2010 | 02:33 AM
cadrad's Avatar
Default climate control sensor?
I pulled the climate control panel to change one of the LCD bulbs and now it only blows out super hot air. Did I bump a sensor or something? thanks!
Old Jan 8, 2010 | 02:36 AM
SuperSport's Avatar
How difficult was this job? I need to do the same thing.
Although, I guess you will not truly know until you figure out the hot air thing huh?
I would have guessed a wire connected to the panel, but of course, I have not seen the back of it yet.
Old Jan 8, 2010 | 05:04 PM
cadrad's Avatar
It was not hard. you pull the leather bezel around the shifter off, remove 4 7mm. bolts that hold on the wood. remove the wood, remove the four screws that hold the unit in place, swear because some *** before you has overtightened the screws and broken the mounts, pull out the unit as far as it will allow, (you cant detach it completely) remove two tiny screws that hold on the back plate, and replace the bulb. Order the bulb first. There is a post I did about the bulbs that gives the part number if you search by my name https://www.jaguarforums.com/forum/showthread.php?t=28398&highlight=climate+control . see also https://www.jaguarforums.com/forum/showthread.php?t=18946&highlight=climate+control
mrplow58
Jan 21, 2024 05:53 AM
Steviedee1st
Nov 28, 2023 06:32 PM
texaspete
Sep 10, 2015 08:34 AM
tberg
Sep 7, 2015 07:32 AM
