gas pedal limiter?
Old Feb 23, 2012 | 04:26 PM
adriaxj8's Avatar
Default gas pedal limiter?
Hello,
I would like to know why there is a piece at the end of the gas pedal. Is it possible to remove? Has any function? Sometimes I fell I would like to have more pedal stroke.
Here is a picture of this piece without the black plastic lid:
Old Feb 23, 2012 | 05:34 PM
Vector's Avatar
That is your kickdown switch. Makes the tranny grab a lower gear when you floor it.
You should check your throttle cable adjustment to make sure you are getting wide open throttle when you floor it.
Search for "throttle cable adjustment" in the 308 section and the info should come up.
Vector
Old Feb 23, 2012 | 05:40 PM
Sean B's Avatar
Only XJR's have a kickdown switch, the NA car's kickdown is controlled by the tcm/ecm.
Old Feb 23, 2012 | 05:47 PM
plums's Avatar
And so ... it is up to the OP to actually mention year and model.
Old Feb 23, 2012 | 10:31 PM
avt007's Avatar
Mine has a big black plastic piece in there.
Old Feb 24, 2012 | 05:06 AM
adriaxj8's Avatar
The model is an XJ8 3.2 from 1999. So if it is not the kick-down what it's the purpose of the button?
Old Feb 24, 2012 | 05:49 AM
Sean B's Avatar
On your car, to stop the pedal travel, nothing else. Looks like you're missing the bung.
max224
Jun 21, 2024 12:17 PM
aode06
Jul 28, 2023 02:26 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
hkmcmast
Nov 29, 2015 06:56 AM
workworkwork
Oct 23, 2015 10:26 AM
