Gas Pressure Shocks??
Old Mar 30, 2016 | 01:35 PM
RonaldP's Avatar
Default Gas Pressure Shocks??
Last Saturday I replaced the upper shock mounts and sway bar end links on my wife’s 99XJ8L with 110,000 miles on it. When I removed the 5, 10mm bolts on the shock mounting plate it did not rise up like I was expecting based on what I have read on the forums. I did have jack stands under the lower a frames supporting the car on both sides at the same height.This should have resulted in the shock being at mid travel or ride height. I made the assumption that the gas pressure was not at factory spec so I ordered a pair of KYB gas-adjust as a replacement. I was surprised that the shock was still very strong in terms of smooth compression and slow forceful rebound. That replacement project will be next weekend. The end links were a lot easier to replace than I was expecting. That’s the long story now the question. Do the factory spec shocks have a higher gas pressure which results in additional ride height? I do think our cat looks a bit front end heavy.
Her car is smother and quieter than before by a noticeable amount. We have owned the car since 2004 and a gradual deterioration is not all that noticeable. Until one day you start to listen more carefully. The upper shock bushings were crushed and crumbling. Now I am thinking about the sway bar body mount bushings. And then…and then…etc.ect.
Old Mar 30, 2016 | 02:34 PM
RJ237's Avatar
The shocks don't affect ride height, tired springs do.
user 652867429824
Jul 16, 2022 12:19 AM
JimC64
31
Apr 23, 2016 05:32 PM
artmde
Mar 17, 2010 04:55 PM
J.Bo
Jan 25, 2010 07:17 AM
