Gear shift assembly molding for xjr 2001
Old Feb 3, 2014 | 06:06 PM
shakil's Avatar
Default Gear shift assembly molding for xjr 2001
Hi again!
This is another part that broke. It is the plastic moldings for gear shift assembly marked D, R, N etc
See attached pic.
Anyone know where I can get one?
Thanks in advance!
Attached Thumbnails Gear shift assembly molding for xjr 2001-image-1862581598.jpg
Old Feb 4, 2014 | 12:01 AM
Rostman's Avatar
It comes just with complete gear selector assembly.
Old Feb 9, 2014 | 12:06 PM
shakil's Avatar
Thank you very much!!!
Are the xjr and xj8 modules compatible?
Old Feb 9, 2014 | 12:09 PM
avt007's Avatar
Since they have different transmissions, I wouldn't think they are the same. They look the same from the front, though.
Old Feb 9, 2014 | 06:02 PM
DavidB's Avatar
This part is not interchangeable between S/C and non-S/C cars.
Supercharged = LNC-6195
Nonsupercharged = LJA-6195
They are still available from dealers but cost several hundred dollars. If you want a cheaper option, start searching for used parts.
Forcedair1
Sep 8, 2025 01:57 PM
Rlover
Mar 30, 2016 10:04 PM
user 652867429824
Oct 28, 2015 10:18 AM
neruda
Oct 18, 2015 01:19 PM
avern1
Sep 8, 2015 06:25 PM
