Gear shifter issues
Old Apr 14, 2015 | 04:32 PM
smatt61's Avatar
Default Gear shifter issues
hello I have just bought my xj8 3.2 2ooo when its cold shifting the gears its ok but when its wormed up its a bit jerky is this normal
Old Apr 15, 2015 | 04:01 AM
smatt61's Avatar
the gear leaver is what I should have said sorry and I do have my foot on the brake lol
Old Apr 15, 2015 | 01:59 PM
smatt61's Avatar
bump
Old Apr 16, 2015 | 03:11 PM
smatt61's Avatar
suppose its ok then ???
Old Apr 17, 2015 | 02:39 PM
smatt61's Avatar
is there no mechanics on this forum or do you need a certain amount of threads for a response
Old Apr 17, 2015 | 05:44 PM
smatt61's Avatar
bumpbump
Old Apr 17, 2015 | 06:21 PM
Cambo's Avatar
I've moved the thread to the x308 section, more people will see it here
Old Apr 17, 2015 | 06:37 PM
Jhartz's Avatar
I don't understand what your problem is. Are you having trouble moving the gearshift lever? Or do you have a rough shifting once you put it in gear?
Old Apr 18, 2015 | 03:26 PM
smatt61's Avatar
yes it sometimes jerks very vicious when changing through the gears when you pick witch gear you want it also jerks if you put the throttle down when your nearly stopped
Old Apr 19, 2015 | 11:20 AM
Jhartz's Avatar
Sounds like the classic A drum failure. Time to visit a transmission shop, unless you are a good tech with the appropriate tools and lifts.
Old Apr 19, 2015 | 02:42 PM
smatt61's Avatar
whats the a drum
Old Apr 19, 2015 | 02:58 PM
RJ237's Avatar
http://jagrepair.com/images/AutoRepa...%20ZF5HP24.pdf
Old Apr 19, 2015 | 04:24 PM
smatt61's Avatar
is it in the gear box im no mechanic I fit double glazing. I have a 28 days on it from a garage.take it back then ???
Old Apr 19, 2015 | 06:41 PM
RJ237's Avatar
In your position that's what I would do.
Old Apr 23, 2015 | 09:57 PM
Bcrary3's Avatar
I agree, take it back there ASAP!
For these cars, a transmission rebuild is quite pricey (new-used tranny is about $800) a complete rebuild can cost you $8k easy. It's not worth it. See what they can do for you.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
user 652867429824
Oct 28, 2015 10:18 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
