Gearbox sensors.
Old Sep 12, 2010 | 12:09 PM
BigKev's Avatar
Default Gearbox sensors.
I need to check the wiring and the sensor for the "input turbine speed sensor circuit malfunction" fault code I have been getting.
Where will I find it? Any ideas?
Old Dec 29, 2012 | 08:31 AM
johnmc's Avatar
Hello BigKev,
I have the same problem P0715 The sensor is on a plastic plate inside the gearbox and cant be checked without taking it apart. The plug is on R/H Front corner bottom of gearbox, I couldnt get plug out it is held in by a screw that is inaccessible.
Post back on here if you solve your fault.
JaguarLover101
48
Jun 12, 2023 10:28 AM
hkmcmast
Nov 29, 2015 06:56 AM
goges
Oct 5, 2015 04:53 PM
3lvis
Oct 1, 2015 01:56 PM
