Hard reset
Old Dec 17, 2009 | 03:09 AM
Fairlane500's Avatar
Default Hard reset
Regarding a comment on the "Hard reset" - "Disconnect negative terminal on the battery and briefly touch the positive to clear all memory". With what do you "briefly touch" the positive? and where? My XJR is stored and the negative cable is disconnected. I'll be reconnecting it after 5 months. Would being unhooked for that time period do a hard reset, or should I follow the procedure above?
Old Dec 17, 2009 | 02:15 PM
H20boy's Avatar
I'm going to take a stab here, if the negative terminal is left disconnected for that long, the stored energy in the computer will be drained entirely...in effect, reset upon reconnection.
You're not trickle charging it while in storage?
Old Dec 17, 2009 | 05:22 PM
No trickle charge. I have been storing cars for the winter since 1990 and never have used a trickle charger, and that included a 99 XJR that I stored for 2 winters. In most cases, with the battery disconnected for the winter, the cars would start right up in the spring after reconnecting.
Old Dec 18, 2009 | 11:23 AM
H20boy's Avatar
don't fix what isn't broke...and all that jazz.
max224
Jun 21, 2024 12:17 PM
ricwel
Jun 23, 2023 05:14 PM
Johnken
Apr 8, 2018 10:21 AM
goges
Oct 5, 2015 04:53 PM
JTC3400
Sep 29, 2015 05:03 PM
