Have an immediate need to "get to work". Hopefully I'll be back on the road soon.
Old Feb 4, 2013 | 08:12 PM
jimlombardi's Avatar
You probably can get your alloy wheel repaired.
Here is a alloy wheel repair shop in Ohio that I have used twice for our 2001 XJ8.
First time when we purchased the car, the full size spare had a broken rim bead ($85 for welding/painting repair plus $14 shipping).
Second time when I ran into a sharp turn curbing, front right rim bent ($100 for repair plus $14 shipping).
Cliff Jacobs Wheel Repair work is outstanding, both rims look like new.
Cliff Jacobs Wheel Repair ; We straighten Bent Wheels
Jim Lombardi
Old Feb 4, 2013 | 09:08 PM
Ipc838's Avatar
@dsnyder: so far the decision is, pay cash. Insurance deductible
is only $500, but the long-run cost will run into the manymany-thousands.
So, off insurance is the current plan of action. As you saw, that
is $200, the rim is a lost cause. It was bent and has been refubished
before, Jim.
Old Feb 5, 2013 | 04:19 PM
Ipc838's Avatar
Despite the way things initially looked, the cradle needs replacing entirely apparently. The oil leak/pressure loss was described by my mechanic as "serious", but he has yet to work out where its leaking from. (he has only glanced at it, and I have class until he closes) the lower control is ok as far as i know, as well as the shocks which are at angles in their mountings. The upper rh control arm is bent. I will get a quote/details tomorrow I suspect.
Old Feb 11, 2013 | 10:53 PM
Ipc838's Avatar
UPDATE:
Pretty good news. The "framerail" (main monocoque arm) is
fine, the lower cradle needs replacing. The oil pressure problem
was due to a hole in the end of my oil filter. So, cheapest possible
fix on the oil presure/loss. Quote is about $2900, so this is not the
worst. I feel like a pillock though and the 'doh factor was very
high on this one. Not sure how long 'till I have the car back though,
being without it since January (having no other car, being too
young to rent) is not fun.
Ian
Old Feb 11, 2013 | 11:00 PM
dsnyder586's Avatar
Nice!
Old Mar 10, 2013 | 01:59 AM
Ipc838's Avatar
The car is back on the road. Tracks straight, front end
feels tight as a drum, new control arms upper/lower on the RH side,
no funny noises from the front suspension.
The guys at the shop recommended a front pad replacement, so
they went to the counter at O'Reilly's and asked for 03 XJR pads,
and fitted them. They only sweep the outer 1/2 of the rotor, so
the car is driveable, sort of... braking is there(ish), they apparently had
bled the system for some reason (Thanks a lot for getting rid of
my $70/L Castrol, without ever talking to me about it) and the pedal
was super soft. Since it was 4:55 on a Friday, it was too late to get parts.
They bled the brakes again for me, and got the pedal harder, so
now I have the car until Monday or something, when I shall continue my
have-no-car marathon. My mechanic told them what pads it needs and
will ensure they are installed.
After sourcing a remanufactered ZF Servotronic from CarSteering.com
for about $325, and sending it to them (they were having no luck
getting a steering rack from used sources) the steering feels like trash.
They said it might be a "break-in" period type deal, this being a re-man.
It is using the original solenoid, but the rack is replaced. at 90 degrees
left it resists turning a lot, and at 270 deg right it will hold itself in place
and you could drive around in circles for hours hands-off. I have put about
100 miles on the car as-is, (being very easy on the brakes) and the
steering doesn't seem to be improving. So on Monday I will discuss sorting
it out with the provider of the rack and disclose my unhappiness with having
a notchy steering rack.
Old Mar 10, 2013 | 07:34 PM
Count Iblis's Avatar
Ian, sorry to hear about your misfortune but glad that you're not hurt and seem to be back on the road.
Sorry I haven't responded to your latest questions on youtube yet- I litterally get about 10 questions from folks via email from online daily and I have so much to do myself IRL.
My car's been off the road for so long- am really considering spending good money and giving it to someone to get my diff jobs done.
Someone talked about space savers: FWIW my car has a full size in the boot- not sure if it was an optional upgrade.
Old Mar 11, 2013 | 12:48 AM
  #28
Ipc838's Avatar
Thanks Iblis (forgot your first name!)
The rates have been really reasonable, 29hrs
on the cradle install but only $85 on align, and
$225 for the wheel, no charge on mt/balance,
it was done for me really well (my mechanic went
to bat for me on getting this done and saved me
a lot of time.) and at low cost (if that can be said).
It was an option at the dealer, the full size spare.
Today I cleaned mine up so you can handle it and
aired it up to 60psi, it was at 30 before, not good.
Get to the YT response whenever you can, I thought
you had just forgotten or never seen it. I can imagine
you hear a lot of questions. Maybe just archive them all
and post here on JF. Thanks for answering though.
My diff is whining, despite receipts for a diff replacement
I have from a now-defunct Jaguar dealer in Southern California,
and I am going to add a few g molybdenum disuphide to it, hopefully
that will stop the stupid whine. I knew in the back of my
mind that this diff was not a leave-alone item.
Ian
Rlover
Mar 30, 2016 10:04 PM
AL NZ
Sep 4, 2015 08:39 PM
pocketrocket
Sep 3, 2015 07:44 PM
dcvickers
Sep 2, 2015 06:14 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
