Healthy Engine?
Old May 25, 2020 | 12:29 PM
Noah E's Avatar
Default Healthy Engine?
Hello, first post on the forums here. I have a Jaguar Xj8 1998 Vanden Plas with just under 100,000 on the clock. I have had her over a year and have been constantly worried about whether the engine is healthy or not when she runs I can't help but hear a pinging noise. Attached is a video of the car running. Any thoughts if I'm just being paranoid or is there something going on? Any input is much appreciated.
File Type: avi
Old May 25, 2020 | 01:26 PM
RA110623's Avatar
Banned
welcome . do compression test and use stethoscope to know exactly where that noise coming from . what type of tensioners do u have? metal or plastic?
Old May 25, 2020 | 01:40 PM
Noah E's Avatar
At the time of my purchase of the car I didn't know about the plastic tensioner issue so I never asked the original owner if he had them replaced. I have been meaning to reach out and ask. Since I don't know I have always just assumed that the tensioners were never replaced.
Old May 25, 2020 | 01:48 PM
RA110623's Avatar
Banned
​​​​​​pull the camcover and take a look if it's plastic change the secondary tensioner asap it's easy and not that expensive probably 100$ including camcover gasket .
Old May 25, 2020 | 01:51 PM
Noah E's Avatar
Don't you need specialized tools such as a Camshaft lock? Also what about the lower tensioners are those less prone to breaking?
Old May 25, 2020 | 02:20 PM
RA110623's Avatar
Banned
they're less prone to break . of course it's better to change everything if u can do it then go ahead it's not that hard if u have fix some cars . high quality kit under 350$ including chains and timing chain cover gasket . check
black onyx did great job
http://www.mediafire.com/file/wnuacw...ement.pdf/file
xalty's Avatar
Don’t risk it. Primary tensioners might get weak and old but they don’t usually wreck an engine.
Old May 25, 2020 | 07:34 PM
Carnival Kid's Avatar
Noah,
That is a pretty noisy engine, might be tappets (valve clearances), I think the first thing I would do is check the oil level and color, it may need an oil and filter change, and I would fill with fresh10/40.
It is also a good thing to check if the timing chain tensioners have been updated, remove the passenger valve cover and you can see the secondary tensioners, if they are brown/orange both the primary and secondary tensioners should be updated,
Old May 25, 2020 | 07:47 PM
Noah E's Avatar
What are the differences between normal 5W-30 and 10W-40? Thanks for all the input from everyone! Also am I correct that an oil change is 7.5 quarts.
Old May 26, 2020 | 04:31 AM
10-40 has a very slightly greater viscosity than 5-30. Modern oils allow for a low viscosity oils like 5-30 and car manufacturers like to boast slightly greater mpg figures from them, but many believe that a slightly more viscous oil like 10-40 gives better pressure at the timing chain tensioners. It's a subject that can be argued ad infinitum!.
As for the capacity, yes an oil and filter change is approx 7-to-7.5 quarts
Old May 26, 2020 | 07:54 PM
Noah E's Avatar
Thanks, I'll start by changing the oil and will take a look under the valve covers when I have time. I'll post on my findings.
Old May 27, 2020 | 10:22 AM
Jhartz's Avatar
I think you have the sequence backwards: check the secondary tensioners as soon as possible. Most engines are destroyed if the tensioners break. Lots of threads, herein. Read up. Better to be safe.
Although your noise seems to be more from the injectors.
Old May 27, 2020 | 07:55 PM
M. Stojanovic's Avatar
Attached is a video of the car running...
The first thing to do is to try to determine whether it is from a crankshaft (conrod) bearing or not.
Do you have the knock when starting from cold or does it appear only when the engine warms-up?
With the engine idling (and knocking), engage the transmission. Does the knock disappear or get quieter?
You can also try this by switching the AC on (compressor engaged) and engaging the transmission. Do you notice any changes in the knock intensity or does it stay the same?
Old May 28, 2020 | 12:50 AM
ericjansen's Avatar
What was said before... don't skimp on a total tensioner overhaul, I have seen more than one butchered chain guide.
BUT AS IMPORTANT, if my EAGLE EYES still work , I see that the coolant hoses on the expansion tank are REVERSED .... change them immediately if so.
Old May 28, 2020 | 07:45 AM
Z07Brandon's Avatar
I agree
Old May 28, 2020 | 09:17 AM
Nice catch Eric, those coolant lines are certainly reversed.
Old May 28, 2020 | 10:24 AM
NBCat's Avatar
In addition to the suggestions posted earlier, check for exhaust leak(s) as well.
Old May 28, 2020 | 06:55 PM
Noah E's Avatar
Wow you really do have eagle eyes. Thanks Eric. I am awaiting a callback from the previous owner if I dont hear back soon I'll just open them up. But I won't be driving it till I know for sure. DO NOT want engine damage!
Old May 28, 2020 | 08:53 PM
Noah,
The coolant lines should be connected as follows.......................
Old May 30, 2020 | 09:34 AM
Noah E's Avatar
Just fixed the cooling lines, thanks again I would have never known. Additionally I have just ordered all the parts to do the tensioner upgrades. Will send update after it's all said and done.
