Heating/cooling
Old 03-18-2012, 09:51 PM
fredd60's Avatar
Default Heating/cooling
Hi, have a 1999 XJ8, very good condition, except that the heating/cooling system is very slow to react. By this I mean that if I set the thermostat to 72*F, on a hot day it will try to freeze me for about 20 minutes, before cutting back on the cold, and on a cold day it will stay fully hot for about 20 minutes.
I think there may be crud in the interior air sniffer, and would like to clean it. Tried to research it on the forums, but only advice was to blow compressed air through it. I would prefer to take it apart to clean it, but can't figure out how to remove the face plate without breaking it. Any advice would be appreciated.
thanks
Pete
Old 03-19-2012, 12:06 AM
Boomer from Boston's Avatar
If you look in the JTIS, it appears you pretty much have to take the dash apart. I have similar issues, and would like to check out and clean the cabin temp sensor. It's not clear to me how you tell if the little sniffer motor is working.
fredd60 (03-19-2012)
Old 03-19-2012, 01:03 AM
fredd60's Avatar
Smile heating/cooling
Thanks for quick reply Boomer. I have downloaded JTIS, but can't get it working properly. Might have to put up with problem until I have to pull dash apart.
Pete
XJL
10-28-2014 12:10 PM
Gunmucker
01-04-2013 05:17 PM
musicaljoe
11-17-2012 04:41 PM
jag-pilot
19
10-19-2012 05:39 PM
Paultje Panter
02-10-2011 12:07 PM
Quick Reply: Heating/cooling
