Heatshields
Old Nov 6, 2014 | 12:09 PM
Corey.boyette's Avatar
Default Heatshields
Hello All... I've got a random heat shield that goes on the driver side (LHD) cat that I can not for the life of me figure out how to install it back on. Can someone possibly help? I've attached files and someone at a dealer has already sent me the part diagram but no one can help me on installation.
Thanks in advance!
Corey
Old Nov 6, 2014 | 01:07 PM
RJ237's Avatar
If you mean you can't get it back down where it belongs, I had a struggle when I did it. Getting it past the hoses and wiring looms takes a lot of maneuvering. I used hex head cap screws to attach it to the bracket, not enough clearance to tighten the torx head screws easily.
Old Nov 6, 2014 | 01:26 PM
I got that one with the 3 torx screws installed no problem, but this one works in conjunction with that one and I can't figure out how.
Old Nov 6, 2014 | 02:57 PM
RJ237's Avatar
What engine are you working on? My XK8 and a 2000 XKR have only one heatshield on the left cat.
Old Nov 6, 2014 | 02:59 PM
2003 XJ8. AJ26 Its a odd combination of heatshields. Its right by where the steering column comes through the fire wall.
Old Nov 6, 2014 | 03:05 PM
RJ237's Avatar
I don't think the 03 used the AJ26, but there is obviously a difference between the XJ8 and XK8, so I don't have a clue.
Old Nov 6, 2014 | 03:06 PM
Originally Posted by Corey.boyette
2003 XJ8. AJ26 Its a odd combination of heatshields. Its right by where the steering column comes through the fire wall. This is what the dealer sent me.
f
Old Nov 6, 2014 | 03:08 PM
Sorry. AJ27 :-P
Joachim1167
Nov 7, 2020 09:18 PM
Matei Dima
34
May 3, 2017 10:39 AM
Stuart S
Sep 26, 2016 04:07 PM
Richter12x2
US Southwest
Nov 4, 2015 03:50 PM
jagxtype
Apr 7, 2008 09:15 PM
