Help 2001 xjr supercharged engine blown
Old Mar 29, 2017 | 03:50 PM
Pirate3120's Avatar
Default Help 2001 xjr supercharged engine blown
I am looking for an engine for 2001xjr supercharged. It can be used, remanufactured or rebuilt. I live in Georgia. Does anyone know where to get one. Looking for something low miles but reasonable! Looking asap! Thanks
Old Mar 29, 2017 | 04:14 PM
grandell's Avatar
Keep an eye out for later model 4.2's as well, they make a nice little upgrade.
I don't know the specifics, but the swap has been done many times both here, and in the XK section
Old Mar 29, 2017 | 04:35 PM
BobRoy's Avatar
Get a hold of Vincent
https://www.jaguarforums.com/forum/p...e-sale-178444/
What is wrong with your engine?
Old Mar 29, 2017 | 04:45 PM
Pirate3120's Avatar
They said the oil mixed with the anti-freeze
Old Mar 29, 2017 | 04:55 PM
omgimali's Avatar
Head Gasket 100%
Old Mar 29, 2017 | 05:00 PM
Pirate3120's Avatar
Hi omgimali, new member Brian. It's in the shop now and was diagnosed for new engine. So what more can you tell me please. Thank you
Old Mar 29, 2017 | 05:05 PM
omgimali's Avatar
There are several factors that cause water to get into the engine oil, including leaking intake manifold gaskets, cracked engine castings and a blown head gasket. What I would do is look under the oil cap and on the oil cap do you see a brown oily sludge like milkshake? if so it is a blown head gasket
Attached Thumbnails Help 2001 xjr supercharged engine blown-milky-oil-cap-1.jpg
Old Mar 29, 2017 | 05:10 PM
Pirate3120's Avatar
Ok yes I did that nothing it was clean. No smoking from the rear. The oil on the dipstick was much higher than normal fill.
Old Mar 29, 2017 | 05:12 PM
Pirate3120's Avatar
It was sitting in the garage for a while and it started leaking oil
Old Mar 29, 2017 | 05:17 PM
4litre's Avatar
Check your messages...
Old Mar 29, 2017 | 05:19 PM
Pirate3120's Avatar
Lol
Old Mar 29, 2017 | 05:20 PM
harvest14's Avatar
I have an 03 XJR engine with 123,000 miles on it that runs fantastic and has no leaks. It's still in the car though, and I don't really have the resources to remove it in the near future.
But, it sounds like yours may not be counted out yet. I would get a more detailed diagnosis before I yanked it out and replaced it.
Old Mar 29, 2017 | 05:22 PM
BobRoy's Avatar
What is it leaking from? It may br easier to fix the leak than to replace the engine. Check the oil filter it could be the problem.
Pirate3120's Avatar
Ok I will Jeff.. Thanks
Old Mar 29, 2017 | 05:25 PM
Pirate3120's Avatar
It would not turn at all. New starter, new battery everything dash just went blank
Old Mar 29, 2017 | 05:35 PM
BobRoy's Avatar
Sounds to me like it might be an electrical problem. How much oil did it leak? Does the starter engage but won't turn the engine over? Could be a ground or possibly the false bulkhead. The engine might be toast but give the symptons, it might ne something else.
Old Mar 29, 2017 | 05:39 PM
Pirate3120's Avatar
Ok here goes sound rrr..Rrr.rrr click no sound.it was a thin stream of oil from the engine straight back to the rear. The oil level was higher than the full level on the dipstick.
Old Mar 29, 2017 | 05:47 PM
BobRoy's Avatar
How did the oil level get that high. The only way I can think of is water in the oil or it was overfilled. Is there water in the oil? How did the car run the last time it was driven?
Can you see where the oil is comming from?
Old Mar 29, 2017 | 05:51 PM
Pirate3120's Avatar
I didn't add oil to it. It looked like it was mixed with anti freeze. No milky substance around the cap or smoke from the rear. It ran rough and stopped running period
Had to tow it.
Old Mar 29, 2017 | 06:01 PM
BobRoy's Avatar
Might be headgasket and if it overheated you might have dropped valve seats. You proably better off finding a replacement engine or you have a lot of work ahead of you. It was worth trying to figure it out.
Good luck.
