Help with Coventry wheels on a 2002 X308
Old Dec 23, 2019 | 07:20 PM
  #41
ericjansen's Avatar
Originally Posted by FwIcf
Hi guys,
I just found a very cheap set of 9Jx18H2 ET35 Milans from an XK8 (all wheels are 9“ wide).
The Milan wheel from the X308 was only 8,5“ wide with an offset of 33.
Do these still fit the X308?
The rear shouldn’t be a problem but what‘s about the front?
Nice catch!
The rim themselves will fit at the front, no problem.
Just your tire choice might be limited there.
If you go 255, it will probably do alright without rubbing the inner liners at full lock.
But if you go the 275 look, it will likely rub.
All depends a bit on the tire brand (great variation in actual tolerances), and the height of the side wall.
Staggered tire width is not really an option, as the side wall shape front and rear will look odd.
Old Dec 24, 2019 | 02:29 AM
  #42
FwIcf's Avatar
Originally Posted by ericjansen
Nice catch!
Thanks for the reply!
I will probably use the 255/40 Pirellis I‘ve still got on my old rims.
Most important is that the rim itself won‘t rub since I bought these to fit over the brembo conversion without using any spacers.
wills12345
Nov 20, 2020 10:44 AM
yardbird
Dec 8, 2016 05:22 PM
Happy Pappy
Aug 15, 2015 06:02 PM
Fastcat
Aug 20, 2011 02:41 AM
THEhomelessONE
Aug 7, 2010 09:49 PM
