HELP! Hooked up my 92mm Maf, IAT reading -40 when it is +80
Old 09-10-2013, 10:55 PM
WaterDragon's Avatar
Default Can IAT sensors spontaneously die?
I wired my 92mm Pro-M Maf the same as before, with the IAT sensor lead to the stock Orange MAF wire and one to ground.
My IAT is reading -40 if it is hooked up or if it is not. This sensor worked before when wired in the same way.
I think a big clue here is that the IAT is reading -40 both if the sensor is hooked up or not. So I've ordered a new sensor, and will re wire it to check for good connections. I'll also use a meter on the sensor and see what I get.
My question is do these things spontaneously die occasionally?
Old 09-11-2013, 01:57 PM
OK,
Stand down from red alert, recall all ballistic missiles.
It was just a bad wire connection.
Old 09-11-2013, 11:00 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
which is, by the way, the big risk you are taking tying all these gizmos into your control system without a clear need for them.
Old 09-11-2013, 11:15 PM
What about the need for speed?
Old 09-16-2013, 04:37 AM
kompressed_xj's Avatar
Lol, I felt it water dragon!
Old 09-16-2013, 07:36 AM
matts89xj's Avatar
These "gizmos" are a necessity on builds of this level lol.
BadKat174
05-26-2023 12:29 AM
silkcat
04-15-2023 04:58 PM
philwarner
25
06-26-2021 05:43 AM
caveforce
38
11-16-2015 10:19 AM
xjrjag
09-27-2015 01:53 AM
Quick Reply: HELP! Hooked up my 92mm Maf, IAT reading -40 when it is +80
