Help to identify a windscreen pillar trim part
Old Feb 24, 2015 | 04:27 AM
RichardPhuket's Avatar
Default Help to identify a windscreen pillar trim part
On both sides of my 2002 XJ8 / 308, I'm missing a black plastic end stop for a piece of chrome trim between the windscreen and front door; at the bottom of the pillar. See dropbox link below. The black arrows show the missing part, and the red arrow shows a similar part on another piece of trim.
I just cut my finger on it, so finally decided to sort it out. However, I'm having trouble finding replacement parts because don't know the part number.
Can anyone help?
Thanks!
https://www.dropbox.com/s/knk75v4192...ted-1.jpg?dl=0
Old Feb 24, 2015 | 11:40 AM
luc's Avatar
luc
Can anyone help?
Thanks!
You are not going to find it. It's part of the drip finisher and not sold by itself
Old Feb 24, 2015 | 09:23 PM
Jhartz's Avatar
I tried to fabricate mine using black GE silicon: sloppy and ugly, but worked for a while; then it dried out completely and flaked off. Running without on the left side, no issues other than it doesn't match the right side.
Old Feb 28, 2015 | 08:02 PM
Thanks for that, but what is a drip finisher? Is it possible to change out?
Old Feb 28, 2015 | 10:33 PM
jimlombardi's Avatar
Jagbits has Part #: HNA5700BE-USED
USED PASSENGER SIDE DRIP MOLDING BRIGHT FINISH FITS 1998-2003 XJ8 SWB FROM VIN 737890 ON. ADDITIONAL SHIPPING WILL BE CHARGED FOR THIS PART. Replaces HNA5700BD
You should call them and probably email the description and photo of the part you need.
Here is the weblink:
Hna5700be
The only images I found about part number hna5700be are illustration and not the actual photo of the part, but someone at jagbits.com should be able to sort this out.
Jim Lombardi
Old Mar 1, 2015 | 10:33 AM
luc's Avatar
luc
it is the full length chrome piece above the windows that stop the water from "dripping"
For your car, short wheelbase, right side, after 2000MY, chrome, the part should be: HNA5700BE
Its kind of pricey as over $250 here
Old Mar 2, 2015 | 08:14 PM
Thanks for the part numbers Luc.
It is pricey, especially since I need both sides and would have to import them into Thailand...
It's a pity, but it looks like I will have to live with it.
Harry Dredge
Oct 4, 2024 05:37 PM
JarodL
Mar 7, 2024 01:39 AM
mcdutch
Sep 4, 2015 03:38 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
TC Johnson
Sep 2, 2015 09:30 AM
