HELP, Periodic clacking noise
Old Feb 5, 2013 | 07:12 PM
  #41
RJ237's Avatar
I use Mobil 1 10-40 in both of my cars. I buy it because Walmart has a good price, but there are lots of good oils out there.
Old Feb 8, 2013 | 09:37 PM
  #42
98JagXJ8L's Avatar
Would anyone know the right torque specs on the Valve covers when i put them on? also is there an order you are supposed to follow when torquing them? greatly appreciated
Old Feb 9, 2013 | 04:19 AM
  #43
xjay8's Avatar
Quite simple...these are plastic units so lightas.
Correct torque spec is 8Nm....whatever that is in Inch Pounds ;o)
Correct sequence for tightening is start from the c3enter in a diagonal pattern.
Before tightening down, make sure the mating surface is clean, the ruibber seal is in it's groove and give a wipe with carb cleaner and wipe dry.
These seals need no sealant added except at the mating face of the front timing cover.
A small dab is all that's required.
Old Feb 10, 2013 | 08:01 PM
  #44
Richy_Jsy's Avatar
The tensioners shown are obviously the metal bodied ones, but I note the plastic chain guides are orange in colour. I was always under the distinct impression that the plastic chain guides on 3rd generation metal tensioners are white. Can these be in either colour ?
I understood the white denoted a higher quality plastic part, less likely to show wear over time. I know I am probably totally wrong in this, but could someone clarify for me as I'm thinking of checking mine as well. I have a late 2k 3.2 xj8.
Old Feb 10, 2013 | 09:53 PM
  #45
98JagXJ8L's Avatar
i was asking myself the same thing, i thought because they were orange they needed to be changed
Old Feb 11, 2013 | 04:27 AM
  #46
Sean B's Avatar
engine oil dyes them orange. Nothing wrong there.
Old Feb 11, 2013 | 05:50 AM
  #47
98JagXJ8L's Avatar
Good to know thank you
mikiep
Dec 20, 2019 07:37 PM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
