1998 XJ8 - no kickdown
Old 07-21-2018, 07:50 AM
cbrit's Avatar
Default 1998 XJ8 - no kickdown
will not go into kickdown acceleration and brings up no failsafe or limp codes, has not been driven in 4 years only 35,000 miles ?????
Old 07-21-2018, 08:29 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
Welcome to the forum cbrit,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X308 forum. This is the place to post technical questions about your model.
Old 07-21-2018, 02:35 PM
Addicted2boost's Avatar
Try using the 'S' button just in front of the cup holder. Make sure the button is in the up position and the red led is lit up. Then try driving the car and see how it behaves.
Old 07-21-2018, 05:22 PM
avern1's Avatar
Received 1,317 Likes on 1,004 Posts
There are 2 main reasons that the kickdown is not working. First the throttle is seeing and communicating to the ECU that you are at Wide Open Throttle (WOT) and second is that your kickdown switch is defective. Since the ECU is seeing something for kickdown and can't match values to determine an action your switch is most likely good.
That leaves you are not at WOT, the common cause for that is stretch in the throttle cable. If you remove the snorkle intake and check the cable it probably has too much slack to go to WOT. You can clip the tie wrap that holds the cable to the throttle body and lift the square plastic holder out and adjust the cable to remove the slack. If memory serves me from the last time I did it you rotate it towards the throttle. Once the slack is out reinsert and apply a new tie wrap.
Old 07-21-2018, 05:26 PM
cbrit's Avatar
thanks very much I will check that but at idle it revs freely, is there a fuel filter, thanks again
Old 07-21-2018, 07:32 PM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
The fuel filter is in front of the left rear wheel, but that is probably not the problem. As Vern suggested, the throttle is not opening all the way, an easy check. It's also possible that the kickdown switch needs adjusting. It's under the throttle pedal and can be turned to adjust. But check that the butterfly is opening all the way first.
The engine will rev freely in neutral, but should not go over about 3000 rpm by design.
Old 07-22-2018, 11:20 AM
vijagra's Avatar
AFAIK, there is NO kickdown sitch for early models.
My 2000 XJ8L is without one as well!
Cheers, John
Old 07-22-2018, 03:15 PM
avern1's Avatar
I am not positive but i believe this is the part number for the kickdown switch LNA6570AD . They were used on the XK8 and XJ8 thru 1999. Then discontinued with the cahnge in throttle bodies.
Old 07-22-2018, 09:13 PM
I know my 98' XJR has a kick down switch under the gas pedal. I too wanted to know what I could do to improve my kick down drivability.
Btw, if you ever need to adjust that switch, you must pull up the carpet to gain access to the electrical connector, unplug it and turn the entire switch and short harness together or else you'll ruin the switch.
Old 07-23-2018, 01:55 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
Sometimes the "switch" is not really one but feels like one (or is not connected). The PCM figures out kickdown/WOT.
Old 07-28-2018, 08:27 AM
grantorino62's Avatar
I had no part throttle kick down as well. It was slack in the throttle cable. Rotating the throttle cable bracket relative to the cable fixed it. I rotated the bracket clockwise to shorten the cable 2 turns.
jonpalley
01-25-2021 10:53 PM
myskoc
08-16-2015 03:27 PM
jimforrest (uk)
08-15-2015 12:04 PM
F1wannaB
03-28-2015 07:41 AM
DavidN
07-30-2011 05:32 PM
Quick Reply: 1998 XJ8 - no kickdown
